2019 Lynx Rave RS 600 – Bolder-Faster-Radical
Lynx Rave RS 600 race sled is reborn for MY19
BRP introduced the new Lynx Rave RS 600 race snowmobile for the record high audience of 18,000 visitors at the Rovaniemi Snowmobile Exhibition. The most visual change in the new Lynx snowcross sled is the new rear of tunnel. The aluminum tunnel has been shortened, and the rear part is made of polyethylene. The new tunnel design makes the snowmobile withstand rough racing situations better. In the case of a mild rear end collision, the rear part is flexible, unlike an aluminum tunnel. In the case of a breakage, the rear part is easy, quick and inexpensive to change.
The toe hooks have been renewed as well. The side support provides more control in corners. The toe hooks are still height adjustable.
NEW PPS²-3500-R rear suspension
The new PPS²-3500-R rear suspension with 3487 mm track length, is a whole new version of the legendary PPS² rear suspension. The rear arm is located closer to the rear wheels. Also, the front arm is updated. The connection rods of PPS swing have been upgraded to stronger ones and the aluminum front limiter strap axel has been replaced by a steel axel. The geometry of the front arm is new, and it allows using lighter center spring without sacrificing performance. The updates of the rear suspension make weight transfer more controlled and provide improved handling in corners as well as better acceleration.
The rear arm attachment point design prevents lateral movement of the rear suspension, providing more controlled cornering.
POWER PACKAGE
The new ECU mapping is made for better acceleration and mid-range power. Thanks to longer gearing (23/51 vs. MY18 21/51), sled pulls stronger and faster than before.
PPS²-3500-R REAR SUSPENSION: 3487 mm track length. Longer track provides more stability and better acceleration.
1) Running boards are more robust, thanks to stronger supports and new design
2) The edge profile of the running board is easy to change when needed
3) Running boards are more horizontal, which makes stand up riding and moving on running boards even easier than before.
TOE HOOKS: The new design gives improved support when cornering. Toe hooks are located more forward than before for better cornering. Thanks to the newly located toe hooks, the rider has more room to move forward in order to get more ski pressure when corneringPILOT RACING SKI: The new ski is tailor-made for snowcross. It is taller than the previous ski, providing improved stability.ECU MAPPING: Throttle response is crispier, and acceleration is faster than before.
BRAKE: The brake disk diameter is 220 mm. Brake disk cooling has been improved and the brake piston is located more forward.
LYNX RS 600
Chassis Radien-RS
Skis Pilot Racing
Seat RS
Handlebar riser 90 mm
Engine Rotax 600RS E-TEC
Number of cylinders 2
Cylinder displacement 599,4 cm³
Bore 72,3 mm
Stroke 73 mm
Peak power RPM 8400
Carburation E-TEC
Fuel 98 octane
Oil mix% 3%
Fuel tank volume 18 liters
POWERTRAIN
Clutch Racing pDrive
Driven pulley Team TTS-04
Engagement 5000 rpm
Gearing 23/51
Brake Brembo Racing 4-piston
DIMENSIONS
Overal length 3170 mm
Overall width 1280 mm
Overall height 1190 mm
Ski stance 1092 mm
Track dimensions 380x3487x44 mm
SUSPENSION
Front suspension LFS Racing
Front shocks KYB 40 HLCR Kashima
Front suspension travel 260 mm
Front springs 28 N/mm
Rear suspension PPS²-3500-R
Rear suspension shocks KYB 46 HLCR Kashima
Springs (Center/Rear) 55/65 Nm
Rear suspension travel 390 mm
