Tre crossmaskiner redo
2014 Ski-Doo MX ZX 600 RS
Viktiga förändringar:
2014 Arctic Cat ZR 6000R
• New spindles (more material removed to reduce weight)
• New ski rubber (improved front suspension handling characteristics)
• New tie rod tubes (larger diameter for increased strength)
• New side panels with added venting
• New driven shaft for improved durability and ease of assembly
• New top bearing in dropcase to accept “floating” driven shaft design
• New track driveshaft and track drive sprockets (revised pitch and tooth profile, broached hex for increased insertion force)
• New running board stiffeners for increased strength and added traction
• New seat cover for improved durability
• New brake caliper with low compression seals for improved level feel and faster-reacting brake
• New idler arm for improved durability
• New lightweight idler wheel mounting blocks (magnesium with 6mm mounting hardware)
• New rear axle adjuster blocks with added nylock nut to prevent track adjustment bolts from backing out
• Modified exhaust (similar to 2012 Sno Pro for improved engine durability)
