felkod på boondocker
kritte
20 dec 2008
30
hej fick en felkod på boondockern på min f7 -05, mag inj error stod det, fel på spridaren lr nåt annat med sprutet? stiftet på ena cyl är vitt på isolatorn med vit beläggn. på elektroden, andra stiftet ok, tyder ju på mager blandning på ena cyl, mvh krille
thullen
Leksand
thullen.se
Från monteringsanvisningen
Injector Errors
A. Intermittent Errors:
The Control Box monitors the signals from the sled’s ECU. If it detects signals on one set of wires but not the other, it
will detect a fault on that injector and display one of the two error messages.
MAG Inj Error Missing or bad signal detected on the MAG (recoil) side injector (yellow or tan wires).
PTO Inj Error Missing or bad signal detected on the PTO (clutch) side injector (green or brown wires).
If either of these errors occur, the Control Box will still function and it will still “try” to make fuel adjustments (as
long as the injector connections are good), but the injector connection will need to be fixed. Check for loose terminals
in the connectors and frayed wires. If the problem cannot be fixed and the error reoccurs frequently, contact
Boondocker to determine if the Control Box and harness need to be sent back to be inspected or serviced.
Note 1: Injector errors that occur infrequently (more than several minutes or hours apart) may be ignored since
they are likely caused by sporadic electrical noise. Try rerouting the Control Box harness so it is kept away from
ignition, fuel pump, and stator wires. Verify that the sled’s ground wire is attached to the frame.
Note 2: If an error occurs more than 10 times (before being cleared), and exclamation point “!” will be displayed
after “MAG” or “PTO” is displayed as shown:
MAG!Inj Error “!” = More than 10 errors have been detected on MAG injector.
PTO!Inj Error “!” = More than 10 errors have been detected on PTO injector.
Note 3: Even though “MAG” or “PTO” is displayed, it is possible the actual fault is on the opposite injector or on
both injectors.
kritte
20 dec 2008
30
tack har just köpt skotern,fick inte mont.anvisn. med skotern ska kolla kontakter o kablar o jordkontakter först :hello:
Carleen
12 nov 2010
251
Löste du problemet? Har nämligen exakt samma fel på min f7a med boondocker box, dock så kommer även xxx injektor error upp och den går skitkasst :(
Mvh
