Panther 660
Falk1
18 dec 2021
Vidsel
Hej, I have a problem with my panther 660 built 2006.when I turn the key, I don't hear the fuel pump and the light is off. The starter turn but he didn't start. I have control the kill switch! Where can I find a wire diagram? Maybe a broken wire??
Maybe someone can help me.
Thanks Stephan
dieselbrum
21 nov 2021
65
13
Hälsingland
If you think it might not be getting any fuel because of the fuel pump or other, you could remove the spark plugs and pour in a little bit of pre-mixed fuel in both cylinders. If it starts then and runs for only a second or two, you know it's not getting any fuel.
Falk1
18 dec 2021
Vidsel
I can check it tomorrow with brake cleaner into the air box. Then I know that the spark plugs work or not. But we have - 33 degrees at the moment.
Reactions: dieselbrum
844
Brakecleaner in the airbox is no good ide, the airbox can explode! Brakecelaner down the sparkplugg hole is safer.
