Vet inte om det redan är postat men jag gör det igen, någon moderator får ta bort det om det blir dubbelpost.
KGK eller ÅF ska väll meddela om detta, men det hör väll inte till ovanligheterna att det blir "missar", som i sin tur kan leda till att garantin påverkas då detta skall åtgärdas innan 19 december som jag förstått det.
Service Bulletins for 2013 Sleds
When determining if your sled is affected by a recall or update only use the last 6 digits of the VIN
Bulletin No: BS201307Bulletin No: BS201312Bulletin No: BS201313Bulletin No: BS201314
Subject: Shift Fork Update
Affected Models: 2013 F/M/XF 1100 cc models within the VIN ranges of 100949-103962 and 808001-808211.
Condition: The existing shift fork may fail where the fork contacts the reverse gear and should be replaced.
Solution: Install new Shift Fork Update Kit (p/n 0637-414) on all affected models.
Subject: Slide Rail End Caps
Affected Models: 2013 M8, M 1100 Turbo, and M 1100 non-Turbo
Condition: The slide rail end caps do not meet Arctic Cat standards on the affected modelsonly and should be replaced.
Solution: Install new Slide Rail End Cap Update Kit (p/n 0637-420).
Subject: Skid Frame Relocation
Affected Models: All 2013 XF models including XF High Country models
Condition: The lower mounting location in which the skid frame was mounted during assembly on XF models may cause adverse wear to the slide rail end caps and wear strips.
Solution: The skid frame should be relocated to the upper locations.
Subject: Skid Frame Front Arm Mounting
Affected Models: All 2013 RR models
Condition:The cap screws securing the front arm to the slide rails may come loose during the operation of the snowmobile resulting in wear to the slide rail.
Solution: Install new RR Front Arm Mounting Update Kit (p/n 0637-421).
