Tjena,
Har samlat ihop Yamaha's felkoder då de ofta dyker upp. Dessa är främst gällande APEX, APEX MTN och ATTAK.
Men gäller även fler 4T maskiner:
PÅ ENGELSKA.. Säg till om jag ska översätta dom! :beer:
Code #
Item
Symptom
Fail-Safe Action Starting Capability Running Capability
#11
Cylinder identification sensor --
No normal signals are received from the cylinder identification sensor Continues to operate the engine based on the results of the cylinder identification that existed up to that point --
Unable --
Able --
#12 Crankshaft position sensor --
No normal signals are received from the crankshaft position sensor Stops the engine (by stopping the injection and ignition) --
Unable --
Unable --
#14 Intake air pressure sensor (open or short circuit) (pipe system) --
Intake air pressure sensor-open or short circuit detected. Faulty intake air pressure sensor system Fixes the intake air pressure to 85.0 kPa. --
Able --
Able --
#16 Throttle position sensor (open or short circuit) (stuck)
Throttle position sensor-open or short circuit detected Fixes the throttle position sensor to fully open
Able --
Able --
#20 Intake air pressure --
Atmospheric pressure Defective values are detected due to the internal malfunction Fixes the intake air pressure and atmospheric pressure to 85.0 kPa. --
Able --
Able --
#21 Coolant temperature sensor --
Coolant temperature sensor-open or short circuit detected Fixes the coolant temperature to 600 C. After the engine starts, the radiator fan relay will be turned on. --
Able --
Able --
#22 Intake temperature sensor --
Intake temperature sensor-open or short circuit detected Fixes the intake temperature to 00 C. --
Able --
Able --
#23 Atmospheric pressure sensor (open or short circuit) --
Atmospheric pressure sensor-open or short circuit detected Fixes the atmospheric pressure to 85.0 kPa. --
Able --
Able --
#30 Oil pressure dropped --
Engine stops when the oil pressure drop is detected Fuel pump and fuel injection are stopped (main relay is off) --
Unable --
Unable --
#36 Faulty ignition --
Open circuit detected in the primary lead of the ignition coil Cut the injection of cylinder in the same group with the cylinder that the error is detected. Example, when the #1 cylinder is defective, cut the injection of #1 and #4 cylinders. Turn on the power to the air induction solenoid to always cut-off the aire --
Able (depending on the number of faulty cylinders) --
#42 Speed sensor --
No normal signals are received from the speed sensor Assumes highest ratio --
Able --
Able --
#43 Fuel system voltage (monitor voltage) --
The ECU is unable to monitor the battery voltage (an open circuit in the line to the ECU) Fixes the battery voltage to 12 V --
Able --
Able --
#44 Error in writing the amount of CO adjustment on the EEPROM --
An error is detected while reading or writing on the EEPROM (CO adjustment value) n/a --
Able --
Able --
#46 Vehicle system power supply (monitor voltage) --
Power supply to the FI system is not normal Grip warmer output is off --
Able --
Able --
#50 ECU internal malfunction (memory check error) --
Faulty ECU memory. When this malfunction is detected, the code number might not appear on the meter n/a --
Unable --
Unable --
#80 Grip warmer switch --
Grip warmer switch-short circuit detected n/a --
Able --
Able --
#81 Grip warmer --
Grip warmer-open or short circuit detected n/a --
Able --
Able --
#82 Thumb warmer switch --
Thumb warmer switch-short circuit detected n/a --
Able --
Able --
#83 Thumb warmer --
Thumb warmer-short circuit detected n/a --
Able --
Able --
#84 T.O.R.S. --
Detecting conditions for T.O.R.S. are satisfied n/a --
Able --
Unable --
#85 Oil pressure switch --
Oil pressure switch-open circuit detected n/a --
Able --
Able --
- Start unable warning Relay is not turned ON even if the crank signal is input while the start switch is turned ON. When the start switch is turned ON while an error is detected with the fault code of number 11, 12, 30, or 50. Engine trouble warning light flashes when the start switch is turned on Unable Unable
Code #
Item
Symptom
#11
Unable --
Able --
Unable --
Unable --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Unable --
Unable --
#42 Speed sensor --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Able --
Unable --
Unable --
Able --
Able --
#81 Grip warmer --
Able --
Able --
Able --
Able --
#83 Thumb warmer --
Able --
Able --
#84 T.O.R.S. --
Able --
Unable --
Able --
Able --
