Ski-Doo Deep Snow
• Specialized package with dedicated con guration and features developed with our Backcountry Experts to conquest the most technical terrains
• RF D.E.S.S. key
• Sea-level calibration available on all con gurations
• Pilot DS 3 skis
• Low handlebar strap
• Two ULTIMATE color choices with panel wrap: Supreme look and nish, maximum protection
• Flexible handguards
• Short riser block (120 mm / 4.7 in.)
• Compact and lightweight FORTY7C seat
• tMotion rear suspension with ice scratchers and adjustable limiter strap
• Shock package with stiffer calibration: Kashima coated HPG Plus front shocks with lightweight springs, HPG Plus center shock with lightweight springs and KYB† Pro 36 rear shock aluminum piggyback with Easy-Adjust compression adjuster (22 clicks)
With an insatiable appetite for dramatic drops, big air, and an unquenchable desire to go bigger than the last time, the 2020 Freeride 154/165 is there for those who bend the realities of the snowmobile world. Available with E-TEC SHOT starter.
• E-TEC® SHOT starter
• Rotax® 850 E-TEC® engine
• REV® Gen4 platform with narrow-design bodywork
• pDrive clutch with clickers
• RAS 3 front suspension
• Ergo-Step side panels
• 16 x 154 / 165 x 2.5 or 3.0 in. PowderMax† Light with FlexEdge track
• KYB† Pro 36 R front shocks and KYB† Pro 40 rear shocks aluminum piggyback with Easy-Adjust compression adjuster (22 clicks)
• Brembo racing brake with braided stainless-steel brake line
• Lightweight deep snow seat
• RER electronic reverse
• Compact digital gauge
• tMotion rear suspension with reinforced rails and ice scratchers
• Sway bar quick-disconnect
• Warm glove box with 4 L / 1 US gal of storage
• Full-length extruded pro le running boards with large openings
• Sea-level calibration available on all configurations
Ski-Doo Trail & Crossover
• Adjustable ski stance
• RF D.E.S.S. key
• Trail performance seat
• Transparent handguards
• Open toe-hold
• 7.2-in. wide digital display
• RS running boards
• ULTIMATE Lava Red and White color with panel wrap: Supreme look and finish, maximum protection
• Backlit multifunction handlebar controls
• Rotax® 850 E-TEC® and 900 ACE Turbo engines
• Backlit multifunction steering controls TURBO shown
• Optional Adjus ent package including rMotion Quick Adjust system and Pilot TS skis or rMotion Quick Adjust system only
• Open toe-hold
• RS running boards
• Forward steering post position (850 E-TEC®) • Rack steering system
• 15 x 137 in. track choice: 1.25 in. RipSaw† or Ice Ripper XT or 1.5 in. Ice Ripper XT
2020 Ski-Doo Expedition
• REV® Gen4 platform with wide-design bodywork
• 20-in. wide Multi-LinQ plate with 125 lb / 56.7 kg cargo capacity
• SC -5U articulating rear suspension with locking mechanism on one side (no tool required)
• KYB Pro 36 aluminum piggyback rear shock with Easy-Adjust compression adjusters (22 clicks)
• HPG Plus front shocks
• RF D.E.S.S. key
• 4.5-in. digital display
• Electric start
• Easy Shift transmission (H-L-N) with RER electronic reverse
• Air radiator with fan
• Deep snow running boards with large openings
• Pilot DS 3 skis
PACKAGE HIGHLIGHTS
• Rotax® 600R E-TEC®, 900 ACE Turbo and 900 ACE engines
• pDrive clutch
• Air Control Suspension (ACS)
• 20 x 154 track choices: 1.5 in. Silent Cobra WT or Silent Ice Cobra WT or 1.8 in. Cobra WT
• RF D.E.S.S. key
• Easy Shift transmission (H-L-N) with RER electronic reverse (600R E-TEC) / electro-mechanical reverse (ACE engines)
• Removable passenger seat and with heated grips • Ultra large LinQ utility cargo box with 131 L / 34.1 US gal of storage
• Hitch receiver with 1,500 lb / 680 kg towing capacity when equiped with an HD rear bumper. (1,200 lb / 544 kg std.)
• High capacity battery
• Forward Adjustable Riser
• 26.5-in. Ultra-high windshield with side de ectors • Pivoting mirrors
• Heated driver’s visor power outlet
• pDrive clutch
• 20 x 154 x 1.5 in. Silent Cobra WT track
• RF D.E.S.S. key
• 26.5-in. Ultra-high windshield with side deflectors
