Aktiv Panther Lång 85 - throttle stays full when I press too much
Kokesh
Rookie sledder
22 jan 2018
15
I've checked the carb, it is clean in the hole where the needle goes. The needle is fine, not scorched. The spring is also fine.
When I reseat the needle carefully, it is fine. But when I press the throttle too much, it seems to be stuck outside of the hole.
It worked for many years, but last week the machine accelerated suddenly when I pushed the throttle too much and stayed fully on. I quickly avoided diaaster by turning the key off.
I thought first the throttle cable was bad, so I replaced it. But it is the same even with new cable.
Any ideas?
Do you hawe oem airbox?
If you drive without oem airbox with or without an air filter the throttle can freeze. They usually happen at full throttle or if you run steady throttle for a few seconds.
They happen at certain temperatures completely randomly
30545
Öppna i Google Översä
