Arctic återkallar....
ExIISx
Krokom Swe
SNOWMOBILE NEWS sponsored by
September 21, 2006
Arctic Cat Recalls Snowmobiles Due To Loss Of Steering Control Hazard
The following product safety recall was voluntarily conducted by Arctic Cat in cooperation with the Consumer Product Safety Commission. Consumers should stop using the product immediately unless otherwise instructed.
Name of Product: Arctic Cat snowmobiles
Units: About 50,500
Hazard: The steering shaft used on certain 2002, 2003, 2004, 2005 and 2006 Arctic Cat snowmobiles can fail at the steering shaft/steering arm attachment. This could cause a loss of steering control of the vehicle and result in injury or death.
Incidents/Injuries: Arctic Cat has received 42 reports relating to loss of steering control on the recalled Arctic Cat model snowmobiles. No injuries have been reported.
Description: The recalled steering shafts were installed on the following models:
All 2002 440 Sno Pro models
All 2003 Firecat 500/600/700, Firecat 700 Sno Pro and 440 Sno Pro models
All 2004 Firecat 500/600/700 (STD and Sno Pro) and Sabercat 500/600/700 models
All 2005 Firecat 500/600/700 (STD and Sno Pro), M5, M6, M7 and Sabercat 500/600/700 models
All 2006 Crossfire 600/700, Firecat 500/600/700, Firecat 700 Sno Pro, Sabercat 500/600/700 and all M-Series
NOTE: Vehicle Identification Number (VIN) ranges of 4UF06SNWX6T100985 through 4UF06SNW26T128280 and 4UF06SNW16T900039 through 4UF06SNW06T900064 apply to 2006 models listed above only. For identification purposes, it is necessary to refer to only the last six digits of the VIN.
Sold at: Arctic Cat dealerships worldwide from May 2001 through April 2006 for between $6,500 and $9,000.
Remedy: Consumers should stop using the recalled snowmobiles immediately. Registered owners have been notified about this recall by mail. If consumers are unsure if their snowmobile is affected, they should call Arctic Cat. Consumers should have available the model name and model number of the snowmobile when they call. The model name and model number are displayed on the registration materials you received when you purchased your snowmobile, and on your operator’s manual. Consumers with a recalled snowmobile should contact their local Arctic Cat snowmobile dealer to schedule the free repair.
For more information, log on to www.arctic-cat.com.
Dr_Stein
Min återförsäljare visste inget ännu, men dom skulle ha ett ÅF-möte snart och då kommer det nog upp. Jag är inte förvånad med tanke på hur en del fogar ser ut.
emmes
1 apr 2006
252
Detta e bara en myt snackade nyss med min åf dom kommer skicka ut ett brev för att mna ska uppsöka sin närmsta åf för att du ska sätta fast en sak där styr stammen går genom chassit....så ingen kommer behöva lämna tillbaka sina skotrar...
JohanAc
17 jan 2007
250
Lycksele
www.inlandets.se
Om du läste noga i den engelska texten, så stod det "free repair", inte att man skulle lämna tillbaka sin skoter :D
/Mr. Finstilt ;)
emmes
1 apr 2006
252
/Mr. Finstilt ;)
man behöver inte alltid vara jätte peting + min engelska e inte den bästa;)
