Hittade 2 till prylar som bör kollas:
While you fellers are looking around in your engine compartment, you might also check the wire(s) connected to your Exhaust Valve Solenoid. A riding pal of mine has an '11 Pro and it started running like s**t. Hit the flipper, pulled hard, then would suddenly shut down and then would start pulling again. Dealer put the D Wrench on it and it threw a code for the EV Solenoid. Checked the wire and it was completely shot. Rewired and now it runs perfectly. A case of another electrical gremlin.
Och Boost III skrev i en anna tråd att man bör kolla upp avg utblåset så inte det fått sig ett veck, kan ge tydl ge liknande symptom.
